Design help - zones?
I have a separate property that consists of a garage with an attached apartment. I need to install an alarm on both and would like the ability for each area to be controlled independent of the other. I’ve attached an over-simplified picture of the layout. Everything in blue should be treated independently from everything in orange, and each should have a panel “P” that should be capable of turning on/off that area.
What would be the best way to achieve this?
You can use an IQ Panel 4 with a IQ Remote PowerG Secondary Keypad. You can use one main panel and once secondary panel and assign each area its own partition. You will then assign each sensor a partition. You will be able to arm and disarm each independently of the other. If purchasing the 319.5Mhz version, you can use any of the sensors below.
Motions:
PowerG Microwave Motion
PowerG Digital Pet-Immune PIR Motion Detector
IQ Motion Detector
Door/Window Sensors:
PowerG Wireless Door/Window Sensor
IQ Mini Door/Window Sensor
That sounds perfect. One follow-up question since this will be my first time working with partitions: will I be able to have each panel default to the partition it is intended for? I’m just trying to keep things simple for the occupant of the apartment.
With the IQ Panel 4, it would depend on the user code assignment. The way it would work is that the panel/keypad would need a user code in order to unlock and be able to arm and disarm the panel. If the user code entered is assigned to partition 2, then when the keypad is unlocked will only show partition 2. If the user code entered is assigned to both partitions, you will be able to scroll up/down through both and arm/disarm both seperatly. I believe that the keypad automatically locks itself after about 1 minute of last touchscreen press.
After using the partition setup for a while, we’ve decided that certain limitations, like lack of smart arming, are not in line with how we want to use the system. A couple of questions:
  • I’d be willing to install and pay for a second system so that the two areas are completely separate. Are there any issues having two alarm systems associated with one physical street address? Anything I should do or note when ordering the second system?
  • How do I revert a system split into two partitions back to a non-partitioned system? I know how to remove individual sensors that I will later add to the second system, but I’m not sure what bringing the current system back to its original non-partitioned state entails.
Thanks for your patience while we looked into this!
Unfortunately, Smart Arming is only available on systems with a single partition, so it can’t be enabled while your garage is set up as its own partition.
There’s no issue having two systems in one location. You would just delete the garage sensors from your current system and add them to the new one. Then disable multiple partition support on your current panel so it goes back to a single partition. After that, Smart Arming will be available.
If you’d rather keep everything on one system, you could also add Automatic Arming Schedules ($4/month). It lets you set schedules that arm each partition automatically at set times, and it can re-arm a partition if no activity is detected after it’s disarmed. Smart Arming isn’t available while this add-on is active. It works on a fixed schedule so its different than Smart Arming but its close. You can find more details here:
If you have any questions, just let us know!
Arming schedules might work for what we want. I will look into that more.
Thanks!
