Deactivate motion sensor when not armed
I’m finding it a bit of a nuisance that when the panel is disarmed, the motion sensors (DSC PG9934) are still recording activity. Is there a setting to turn off reporting when not armed? Thanks!
With a PowerG motion detector you can edit the High Traffic Shutdown setting in the sensor programming menu on the panel. This governs how frequently it will be able to report. One of the options is to disable the motion detection while disarmed.
Settings > Advanced Settings > installer code > Installation > Devices > Security Sensors > Edit Sensor
Thanks, I did get as far as “Edit Sensor” but never thought to check “High Traffic Shutdown” for the solution!
