I have a recirculation pump that is on demand. We hit a remote button to trigger it that turns on the pump that circulates water so that our tankless water heater produces hot water for the house.
The range is very bad on the remote switch.
You can run the pump by switching the power off then on again. You can do this through ADC and Alexa and a zwave outlet. The problem is that you have to run two commands (Turn off pump, then turn on pump"
Is there any way to program this through ADC and Alexa so that I say “Turn on Pump” and it first turns it off, then on? Can it be done with IFTTT. I am not sure ADC works with IFTTT
I may have to buy a Wemo outlet to get this to work but rather not.
