CT30 Thermostat not showing in ADC - need to upgrade
Hi All,
I just signed up and after flashing 2gig GC2 panel I got mostly setup successfully.
My CT30 thermostat is not showing up in ADC though. I just saw the forum post about the CT30 not being supported any longer so I guess I need to replace the thermostat.
To keep the upgrade simple I would like to just replace it with a CT32. I found this one: https://www.ebay.com/itm/Radio-Thermostat-CT32-7-Day-Programmable-Z-Wave-Thermostat-USED/202414319485?epid=826900416&hash=item2f20d5677d:g:RX4AAOSwVVpbZNaH&autorefresh=true
I’m not sure if it will work though. On the ADC site it specifies specific firmware versions: https://www.alarm.com/partners/ecosystem.aspx
Also, this CT32 comes with a zigbee radio. Will the CT30 USNAP Z-wave radio I already have work with a CT32?
Thanks,
Sarel
I think this may be a better option. It looks like a much newer version and comes with z-wave radio.
Still have no idea what the FW version is and if it is supported though.
You may be able to ask the seller to verify the firmware version of the Tstat if you would like to go with the CT32.
Any sold as “New” should be fine, but I would verify if possible just in case they are selling old stock.
Other compatible thermostat options can be found here.
