Hi there. Sorry if already asked; searched forum and didn’t find answer.
I want to signup for service and monitoring for an existing 2GIG system inheriting.
> I have the user code, and the installer code
> Using your site’s tool, my serial number reports ‘unregistered and can be monitored’ and is ‘CDMA radio on Verizon running firmware 601184 and is two way voice capable’
> According to my Radio Status screen, my firmware version is ‘V1.13_PRODUCTION’
> Previous alarm installer was Reliant Energy, and appears to be running their firmware, as the splash screen on the GS2 is branded with their name
Questions…
#1) Now I know your site clearly states ‘If you are coming from a security provider who uses proprietary firmware with their alarm panel, you will need to update the firmware on your panel.’. So I am sorry to ask this, but, do I really need to perform a firmware upgrade, meaning, do I really need to but the $25 cable and flash to a generic 2GIG, or is the fact that I’m on V1.13 enough (even though it’s branded with the previous security provider’s firmware)
#2) If I already own a FTDI TTL-232 USB cable, is someone able to tell me the pinout order of the cable you sell so I can make sure I plug my cable into the GS2 correctly?
#3) I’m trying to determine if I really need Gold vs Basic. Can someone explain what the difference between ‘Sensor Security Monitoring (All Sensors)’ and ‘Sensor Activity Monitoring (50 Sensors)’ is?
#4) What is ‘Quickbox Integration’?
#5) Can you expand on what ‘Wireless 2-Way Voice’ is?
Thank you. I think I’ll be ready to signup for service once I understand the answers to these questions.
Questions…
The logo in the bottom right does not indicate a custom firmware variant. In fact the firmware versioning should be different (for example, 1.11 is not a production version, but a specific dealer used it)
Custom firmware is very very rare. 1.13 would be standard firmware and you would be able to get started without an update if you wish.
I can only recommend using the 2GIG Update cable to perform any local updates.
Certainly, this page explains the difference in detail.
Quickbox is a model of small Z-wave biometric safe for valuables/handguns. Model #: Z-QBBIOZW
2-Way Voice is an optional service on panels which support it where the panel initiates a call between itself and the central station as the first point of contact for alarm signals, and communication occurs through the panel speaker/mic.
The GC2 is compatible with 2-Way Voice natively. Some other panels require additional hardware.
2-Way Voice requires Gold Interactive and of course 24/7 Central Station Monitoring.
Sorry for the superfluous post, but just wanted to mention that based on your responses, I did signup for new service (not under the original account ‘Bonuts’ but under this account). Just submitted all my information, waiting for next steps. Thanks again
