Anyone have issues integrating Qolsys IQ Panel 4 (4.5.1)? It keeps showing up as offline with a yellow icon in Composer. And Lua shows this:
OnNetworkBindingChanged(): idBinding = 6000 bIsBound = false
OnNetworkBindingChanged(): idBinding = 6000 bIsBound = true
OnNetworkReconnectTimerExpired: Attempting to reactivate network connection…
Starting Timer: NetworkReconnectTimer
If I power down the panel or disconnect it from my network, the icon would change to red. The below was done to try to integrate or troubleshoot.
Reserved IP (confirmed IP on panel info matches what was reserved)
Changed to 6 digit code (is this still necessary?)
Enabled 3rd Party Integration on IQ4 Panel and let it reboot
Installed driver with the token and made connections within 10mins of rebooting IQ4 after 3rd Party Integration is enabled
Tried making connections within via both methods, SDDP and reserved IP
Rebooted C4, IQ4, and router
Master reset the IQ4 Panel and restarted fresh
Tried regenerating the token
What could be the issue? IQ4 is on software 4.5.1 and WiFi and cellular tests both passed. I was able to update the panel software via WiFi.
