Only Alarm.com model cameras are compatible. You can view a list of compatible models here.
1080P is the max res on those models currently.
There is a balancing act between resolution and bandwidth requirements. The higher the resolution, the greater the bandwidth demands. With one or two cameras it probably won’t matter much, but if you are considering more than that it can have a significant impact.
