Connecting a 2GIG HD100
Hi,
I have not been able to get my HD100 Camera to link up and work with my GC3 panel, despite following all the written directions several times.
Can you provide me detailed instructions for getting this done?
Thanks
Happy to assist!
Please note, the HD100 does not connect directly to the 2GIG GC3 panel. Alarm.com compatible cameras are connected to Wifi and communicate directly with Alarm.com.
In order to add a camera to your Alarm.com account, navigate to the ADC webpage, click Video → Settings → Add Video Device and follow the on screen prompts.
With the HD100, you will want to connect the camera first to the internet via ethernet cable or WPS. Once connected you should then see the option to add the camera via the Alarm.com webpage once the LED on the HD100 has turned green.
You may be prompted to factory reset the camera during the initial connection process. This can be done by pressing and holding the B button on the back of the camera for about ten seconds.
The manual can be found below.
2GIG-HD100-Manual.pdf (190 KB)
