I manually added it. In the initial enrollment, under edit, the Hardwire source was listed as S-line. When I added the hardwire manually, S-line didn’t appear as a source. It currently says SecurityRF-319. The tamper is still in place. There is no error code. After triggering all of the sensors attached to the hardwire, it seems to be functioning properly. The error message is gone. Is the source issue a cause for concern?
The source can be selected and changed manually. If you select SecurityRF 319.5 you will not get the benefit of S-line encryption, but for the Hardwire supervision zone this is mostly irrelevant. SecurityRF-319.5 should be fine.
I am seeing no errors on the zone in the back-end and all status is now showing appropriately for all the zones.
Should it says motion detector activated when no motion?
Yes that is normal. See this thread for details on motion detector status in ADC.
