Configure panel programming on a 2GIG Go!Control, GC2, and GC2e
To access programming:
  1. Tap Security.
  2. Tap Menu.
  3. Tap Toolbox.
  4. Enter the installer code. (default 1561).
  5. In the Toolbox, tap → to scroll to Installer Toolbox.
  6. Tap Installer Toolbox.
  7. Tap System Configuration. This section allows you to add and edit wired/RF sensors as well as the entering/editing of individual programming options (called Questions).
    • To scroll between options on the control panel, tap the left and right → arrows.
    • To move to the previous or next prompt tap the up and down ↓ arrows.
    • If a programming number is known, tap Go To and then enter the programming number to adjust.
  8. Enter or select the desired value for a Question.
  9. Once complete, tap End.
  10. Verify Save changes is selected, and then tap Exit. The panel will automatically perform a power cycle.
