Just installed my 3g module in my Concord 4. When I go to do my cell programming in get a failure bus 2 error. The bus LED is blinking quickly and the auto LED is blinking every few seconds. The left bottom LEDs are solid red and yellow. Please help .
Can you post a photo of your wiring, at the module and panel board? Did you power down the panel completely before installing?
what i did is cleared the memory and re learned the sensors. I no longer have any Bus errors which is nice. How can I “learn” in my smoke and carbon detectors? Also, the green light on L4 of the cell module only blinks for a second or two before turning off and coming on again. Would this mean i only have 1 bar of cell coverage? is it supposed to blink quickly?
For a Wireless Smoke you’ll want group 26 and for the wireless Carbon, youll want group 34.
Start with the panel disarmed. Then hit 8 and the keypad will say
Enter Code
Type in your installer code, then you should see
Enter Command
Punch in 0 0 and it should say
System
Programming
If you do not see this screen you may need to try the previous steps again without any pauses,
Hit # and you will see
Security
Press the down arrow to get to
Sensors
Hit # and it will say
Learn Sensors
Hit # again and you will see
Sensor Partition
1
Hit # again and it will say
Sensor Group
0
Enter in the correct group for the type of sensor you are adding, then hit # and it will tell you to
Trip Sensor
1
Or it will tell you to trip the next available sensor number, if you already have some sensors programmed in.
For wireless devices tamper the sensor
The keypad will beep and go to the next sensor number. To change the next sensor group before you learn in the next sensor hit * , enter the correct group, and then hit # . If the next sensor is going to be the same type as the last one you can simply trip it now without changing the group.
When you are done adding sensors hit * * * to get back to System Programming
Hit the A (up arrow) and it will say Exit Programming Ready then Hit # to exit programming.
How many times does it blink each time? L4 Indicates cellular signal level as a
number of flashes (1 to 5).
The L4 stays lit for about 2 seconds then goes off for about 2 seconds. This repeats continuiusly. Is it supposed to blinking rapidly or for about second as the other L5 light does?
