I am looking to replace my CPI Security Concord 4 based alarm system. CPI installed a system that included cellular communication and two-way voice about 12 years ago. The service was good throughout the years, but now is the time for me to update and take control of my system.
I would greatly appreciate it if you could look at my current system and provide recommendations for a replacement system. I also have some additional questions at the end.
Present System – We use the Stay No Delay feature the most (Press Stay and 4) the system would arm to stay with no delay and no countdown. When going out we used the standard Away feature (Press Away). Finally, we liked the ability to disarm the panel silently by Pressing *5 then Disarm then the code which resulted in a silent disarm.
These are the system components:
CPI Concord 4 Alarm Panel with daughter board
CPI - ADC-200M-EVD-L GSM Cell Radio
2-way Comm Integrator Module
2 – wired keypads - replace
1 – wired internal siren – DSC SD15W-ULF – will keep
1 – wired external siren – located in eave of attic and I can’t determine brand or current rating
1 – wired smoke detector – will replace with System Sensor
1 – wired motion detector – will keep
2 - wired entry doors – will keep
13 – wired windows divided into two zones All the windows have their own sensor and hardwire (I plan to divide the windows into 8 zones)
1 – entry door wired contact to wireless using GE 319.5 Crystal Maxlife Door/Window Wireless Sensor 60-362N transmitter located in the wall box behind the main keypad – will keep
1 – Interlogix 60-873-95 Wireless Glass Break – will keep
1 – Interlogix 600-6520-95 Wireless Carbon Monoxide Alarm – will keep
1 – Interlogix 2 button Keyfob either 60-707-01-95R or 60-832-95R no marking on device – will keep
Here are pictures of the old system Concord 4 and GSM Comm, pictures of the other components are available if needed:
Concord 4 Panel
New System
I would like to use the existing wiring for windows, doors (except the door wired to the wireless door sensor), Motion detector, internal and/or external sirens, and new wired smoke detector.
One possible configuration I have looked at is:
Qolsys IQ Panel 4 as the main panel by entry door (Use existing keypad wires for power)
Qolsys IQ Hardwire 16-F Large Enclosure for wired doors, windows, motion detector, new smoke detector and siren.
Qolsys IQ Remote PowerG for second panel upstairs (when available).
Questions:
Will the Interlogix CO Detector, Glass Break, Wireless door transmitter for the Garage Door and Keyfob work with the IQ 4 Panel (IQP4001)?
Siren Question – Can I use both sirens on the 16-F or would I need to add a relay and power supply to use both, if not would I be able to use just the interior DSC siren?
Does the IQ 4 Panel come with the default installer and dealer codes? Does the panel come with all the factory default settings?
Can you suggest an order for the installation? (i.e., Should I install the Hardwire 16-F first, then install and activate the IQ 4? Then learn in the 16-F. Then learn in the wireless items.
To learn in the wireless door contact which will be located directly behind the IQ 4, can I run the IQ 4 on battery and still use the learn in function?
How long does it take to receive the hardware after order placement?
When does the Surety service trial start?
Do you have yard signs and stickers?
Any other tips, hints, or suggestions?
Thanks in advance for all replies.
