The thermostat rule where if you leave a window open it changes / disables the thermostat only sees my doors and older non-combo sensor windows. my newer window / shock sensor aren’t showing up:
sensor:
In my device lise they show up as “Contact: Multi-function” which is why I assume.
It looks like it does see it as a multi-contact sensor instead of just a regular sensor. I’m waiting on a response from Alarm.com and I will also contact Qolsys on this.
Alarm.com mentioned these sensors are not eligible for this rule. I did put in a request for this to be added but there is no guarantee of when or if they will.
