I am looking for a combined CO2 and Smoke detector that is compatible with the Qolsys panel - any ideas? I saw a first alert one that is Z-Wave compatible but don’t believe that will work with the Qolsys panel. I really don’t want to have to buy the individual Qolsys Smoke AND Carbon detectors due to the cost and the reality of having 2 detectors installed next to each other in each area of the house. We already have a load of individual detectors in bedrooms etc but I want to put a dual sensor one centrally on each floor that would be connected to the panel.
If I cannot find something I am considering going to the Nest Protect instead as this will do both and they will trigger each other should they detect something/go into an alarm state, but this removes the direct integration with the Qolsys panel and automatic Fire dispatch in the event of real emergency.
Is there an updated list of compatible security and life safety devices? I purchased a Qolsys IQ Panel 4 (2GIG & Honeywell 345MHz), and have tried to add a ZCOMBO and it just appears as “Other”.
Here is a link that I found to compatible devices. The PowerG and 345 MHz devices would be compatible with your panel. I believe Z-Wave devices are still unable to generate alarm signals.
Z-wave sensors will not generate alarms of any kind on the Qolsys panel. Secondary Z-wave controllers cannot initiate alarms on the Qolsys panel. No Z-wave device can do that. Only supported alarm sensors.
