I’m likely going to order the GC3 tonight but one concern I have is cellular signal strength. I’m getting 1 to 2 bars out of 5 when I force my iPhone into 3G for Verizon. Similar results for AT&T. Is this a good indication of what the panel will see?
...is this a good indication of what the panel will see?
No
You will want to use the link provided above. Machine to Machine communication is not using the same voice network for carriers, so you typically cannot assume a correlation.
OK. Thanks for the information. The check says the coverage is good. I’ll buy the panel and see what happens.
