Is it possible to “Z-Wave enable” my ceiling fan? It would be great to leverage my alarm.com schedules/rules. I see several switches made by GE when I “google”… Was unsure if (a) this capability exists and (b) if it would work with ADC.
There is no fan specific UI, so they will show up under light switches, but same control applies. You can set fan speed via the same slider as a dimmer switch if I recall.
Ah, gotcha. Well I know the Leviton model actually worked with 2GIG on a much older firmware so I presume it should still be fine compatibility wise. (although those could be famous last words)
I am not certain on the GE you link, never tested. Would be worth a try from a reputable seller with a good return policy. It would just function like a dimmer switch from ADC if it has speed controls and works with 2GIG.
I had an extra Aetech in wall module laying around awhile back, Works if you only want on/off. gotta use pull cord on fan to change speed which isn’t an issue as I leave it on med. The GE switch wasn’t available at that time. hope this helps.
