Trying to program in a 2gig image sensor that I had programmed in before but panel’s transceiver failed and was replaced. I took it off of the network after having problems with it being tripped.
I’ve tried standing in front of the panel, hit learn then inserting batteries into the sensor. Keep getting ‘learn process failed’.
Also tried hitting the reset button for 3 seconds and for 10 seconds with same results.
All the info from when it was on the network before has been cleared.
Any suggestions?
