I have a Schlage FE599 Z-Wave lock that I want to connect to an IQ Panel 2. I can’t get the lock to enter Z-Wave enrollment mode. I’ve tried these combinations several times each.
Press Schlage button
Enter 6 digit programming code
Press 0
and the reverse
Press 0
Either way when I get to the 4th digit in the code the light turns red as if I’ve entered an incorrect user code. How do I enter the 6 digit programming code without getting stopped at the 4th digit?
I know this is 2 1/2 years late for the OP but in case someone else finds this thread in a Search, here’s the steps to include FE599 into your Z-Wave Network;
Make sure your Z-Wave Controller is in close proximity to your FE599 (since it is not Z-Wave Plus).
Put your network controller into “Add” Mode
Press the “Schlage” Button and it will flash red three times
Enter your six digit Programming Code
Press the “Schlage” Button again and it should turn blue
