You can now easily cancel pending commands (when the command is not received by the panel) for panels, Z-Wave® locks, and Z-Wave garage door controllers. When a device command fails to complete after three minutes, users will receive a push notification or an in-app pop-up message. From there, you can go to the Activity timeline for more details, tap the event, and select the “Cancel Command” button for quick cancellation.
This feature helps prevent pending actions from occurring later than expected, and potentially at an undesired time. Note: If a timed-out command is not canceled, it will continue to try to connect. To access this feature, you must have the mobile app version 5.10.2 or later for iOS, or version 5.7.7 or later for Android. Mobile app > Pending Command Pop-Up > Go to Activity > Tap Event Row > Cancel Command
