Trying to reuse old frontpoint 319.5 sensors. I have qolsis 2+.
Is the only way to add them from installer menu? Or can I do it from the app somehow - I looked but can’t see how to do it there.
RF319.5 sensors are added to the panel locally, this is not possible from the ADC app/website.
The Installer Code is needed to access programming, the default code is: 1111
The below guide will walk you through programming of RF sensors:
If you do not know your Installer Code, and your code is not the default, you can use the System Manager feature in your Surety account to set a new one
