Good morning, folks!
I currently only have two cameras set up inside my house. Both downstairs, and both in the same room. (My whole downstairs is just one room.)
ADC-522IR - Just above the SVR and gateway, maybe 2.5 feet from the latter; &
ADC-V523 - On top of my kitchen cabinets overlooking the whole room. About 10-15 feet from the SVR and gateway.
These devices aren’t separated by any walls, unless you count the bookshelf.
Both are connected through WiFi; and
according to my AT&T smart home manager app (might not be reliable), both are getting a full signal.
The main issue: The V523 has been dropping out a lot the past few days. I will try to look at the SVR, and there are whole blocks of time where it says that particular camera wasn’t recording. I’m assuming that means it was disconnected during that time, and some of these blocks are hours.
Both cameras are currently working. The SVR has a green light and the live feed on the web app has both cameras active. However, I did have to power cycle the V523 twice this morning before it would reconnect.
The light on the camera itself was green, and always is, but there was no live feed and it wasn’t recording to the SVR (which did show a red light).
The troubleshooting page on the website wouldn’t load.
I recently moved the location of the camera, but didn’t even need to unplug it to do so. I just moved it to another cabinet. And the location now is actually much closer to the gateway than it has been the past few months.
The questions:
- How do I fix this for good? Should I try a factory reset?
- Notwithstanding the signal strength on the AT&T-SHM app, can you see a weak signal or something else that may be causing the issue on your end?
- Lastly, I’ve never received a notification that the camera wasn’t responding, despite that being in my settings. Can you hazard a guess as to why I wouldn’t be getting those notifications? It would be quite helpful to know how often this has been happening rather than just by chance when I sign on and notice myself.
2nd, less crucial issue: The time stamps when looking at the SVR are wonky. None of them match up. The two cameras seem to be anywhere from ten seconds to two minutes apart. And they are both different from the timestamp on the SVR controller in the website. Again, anywhere from ten seconds to two minutes difference, depending on which camera I’m comparing the web controller timestamp to. The V523 is always ahead of the rest. This is a consistent issue lately as well.
The questions:
- Is the SVR supposed to show playback video from all cameras in sync with one another, time wise?
- If so, how do I realign the timing on my SVR between the cameras?
The second issue is mildly annoying, but not something I consider detrimental to the functionality of the system. If something were to happen, I could still piece together what went down without the times being perfectly aligned. But if it can be fixed I would like to do so.
Thank you so much for all your help.
