Bypassing an armed sensor
Is there a way to bypass a sensor once the alarm is armed? E.g. a window sensor
In order to bypass a sensor while you’re system is armed, you would do the same procedure to bypass individual sensors while the system is disarmed.
  1. Security
  2. Menu
  3. Enter your Master Code
  4. Bypass Sensors
  5. Choose the sensors you’d like to have bypassed.
Once your system disarms, those sensors should revert back to normal and will need to be bypassed again if you want to open them while the system is armed.
