Is there a way to replace the already installed standard smoke detectors in my home (which I don’t think communicate with adc) with ones that can communicate with the alarm monitoring center? I know I could install additional ones but I don’t want smoke detectors everywhere and I’d like to cover up the holes in the ceilings. Are there wired options that can be used to replace pre-existing detectors? Or what would you all suggest in this situation? Thanks so much for the help.
I would recommend for this when u buy the new detectors that tie in too the alarm just take the old detector down and place them in the same spot the old one was
That’s what I was hoping was an option but I wasn’t sure if or how it would fit into the ceiling mount.
The best option would be dependent on what model of detectors you have currently.
Can you confirm the model number?
Are they AC powered interconnected smoke detectors?
If they are interconnected (meaning if one goes off they all sound) then you can monitor all of them with one Firefighter. The 319.5 mhz version is below:
Oh that’s a great solution! Didn’t know that existed.
