Battery replacement chirping sound
How can I remove the chirping sound for battery replacement? I can hear that even after
replacement. Thank you
Which device did you replace the battery in?
When replacing a battery, we generally recommend leaving the old battery out for at least 2 minutes before putting a new battery in. This helps ensure that a low battery restore signal is sent to the system once the new battery is inserted.
