IQPanel 2+. Battery died and I replaced with new. When battery is connected system won’t boot. However, when I remove the battery system boots and works correctly. I tried another new battery and had the same issues. Solutions?
Did you disconnect the transformer, then connect the battery, then connect the transformer again?
When doing this, do the LED lights flash any colors?
If it flashes red for a short period of time, it may just be that the new battery is dead. You can force charge it by repeating the steps of disconnecting both the battery and transformer, connecting the battery first followed by the transformer. This may take up to 15 attempts. Do it until the red LED lights remain on and wait. The panel will turn on after about an hour. If the led lights turn off, follow the above steps again.
