Looking to get the specs for the barrel connector specifically designed for the AC2-PLUG? I want to order just the connector to attach it to a longer than the 10 ft cord that is preconfigured to the 2GIG-AC2 Plug. Also are the power ports on the backside of the 2GIG GC2 panel and at the bottom of the TS1 wireless Touch Screen the same size? Thanks
The 2GIG-AC2 Plug works with the GC2 or GC3. There are various versions of the TS1 and some of them do have a barrel connector jack for power, the older ones only have screw terminals for power.
As for the exact specs of the barrel connector itself, I could not say. 2GIG techs may know however.
Be sure to refer to the manual of the devices you are intending to power to ensure you are using the recommended wire gauge for the length of run you are going with.
