Is there a way to set a priority on rules so that one doesn’t override another?
IE: I have a rule that when a door is opened a few lights are turned. I have a 2nd rule that turns the same lights on (and off after a shorter amount of time than the first rule) when a motion sensor inside the house is activated. But the way things are working now, the door opening is being overridden because the 2nd rule (motion sensor) is being triggered. And therefore the lights are turning off before I’d like them to after the door opens.
I’d like to effectively group the 2 rules, or write an exclusion scenario when the 2nd rule wouldn’t come into play.
Is this possible or in the works? Home automation is a huge part of why I signed up for SuretyDIY. The current system is good, but creates some frustrations too.
