I can send commands, but ADC cannot verify if commands were successfully received. Communication issues.
ADC is not seeing if I open sensors, etc (if I arm panel it still thinks panel is disarmed).
See post found here.
We discovered an issue on Friday 10/31/2014 which slows incoming communication to panels (I believe it is limited currently to AT&T modules.)
The symptoms should present as 10 minute+ wait times for commands to register. Sending a signal out occurs immediately in known cases, and actually expedites the acknowledgement of any commands sent.
Alarm.com is aware of and working on resolving this issue.
