Hello! We recently bought a new home and switched security providers and were told all the same features we had with previous provider would still be available with the new provider. HOWEVER we are no longer able to create an automation rule that arms the system when the door lock is activated by the button only. If we lock the door manually (which happens if we are inside the home and wish to lock the door after answering it) - the automation rule goes into effect. Our last system was smart enough to understand that if the door was locked manually, the rule should not be activated to arm.
The automation rules only allow for time exceptions - which we do not want as we want the system to be armed anytime the lock button is pushed on the outside of the door.
Calls to our provider have not resulted in any solution. Anyone out there that can help?
