Arm Stay—can I make the countdown always silent?
Just what it says in the title: I have the Qolsys IQ Panel 4, and I set it to Armed Stay every night before going to bed. And the dang thing beeps loudly for 50 seconds, then the voice counts down from ten, and I’d like it to just shut up. I see that there’s a little option, each time I set it, to have it count down silently. Is there a way, though, that I can just have it automatically silent, without the extra screen tap each time?
I did just notice that it seems like I may be able to do this through the app, in which case I’ll simply try to remember to arm it that way instead of at the panel. But I’d still love to know if there’s a panel setting as well.
No, though there is a separate work-around for this.
Enter panel settings and go to Advanced Settings > installer code > Installation > Security and Arming.
Scroll down and turn on Arm Stay - No Delay. This setting will result in no countdown timer whenever the panel is armed Stay.
I’ve been looking to do the same. While you can’t make the Arm Stay button always silent, you can make a new Scene, or modify the existing “home” scene that sets Arm Stay. You can set that to have the “silent arm” checkbox checked, and then use that Home scene every night.
If you have a smart home you can also use Alexa or Google to run that scene (manually or every night at a certain time).
