After moving in to our new home I have had nothing but problems with my 2GIG panel and Alarm.Com.
I am currently unable to arm/disarm my panel via both Android App and iPhone App. I am unable to trigger my Z-Wave switch via the apps.
As far as signaling goes, your signal strength looks just fine, however your panel is reporting an improper firmware version to Alarm.com which is likely causing the issues.
What version of firmware does your panel show, specifically? Go to Security - Menu - Toolbox - Master Code - Version.
That’s what I expected. 1.14 was a base version released for only a couple weeks before 1.14.01. 1.14 has an issue that can cause the panel to not report correct versioning info to back-end systems.
To troubleshoot further (and it looks like it may just resolve the issue itself) you’ll want to update the firmware to 1.14.01.
