Hi all,
I have Qolsys 2 panel and a couple of adc t2000 thermostats. I am having a minor annoying problem with the current room temperature not updating that often in the app. Basically if I open up the app and go to the screen where the current room temp(not the temp setting) is displayed, it is always almost an “old” temp. Once I keep the app open and click around the app a bit, the current room temp updates. So for example, the thermostat on the wall says the current room temp is 70 degrees, I open the app and it says the current room temp is 65. I keep the app open and click around the app for a bit, then the app changes and catches up and says 70. Again this is the current room temperature, not the temp setting.
Is there a way to get the thermostat to update the app more frequently? I couldn’t find a setting, but hoping there is one…
