It looks like Aotec has a new water sensor with a lasso and dock. If you google it it should come up on amazon. The lasso allows you to lay the cable around a water heater etc and will pick up a leak at any area around it. It looks to mimic the honeywell lyric water leak execution which I’m a firm believer in. Do you guys know if 2gig or alarm.com have any plans to incorporate this into use? I would love to use these or a lyric like detector for a couple areas in my basement. Thanks guys!
Here’s the url for the dock. They have some pics of the lasso as they call it.
Currently, there is not eta on compatibility with Alarm.com, nor would I anticipate it.
Alarm.com compatible panels at this time do not support any Z-wave Sensor devices (environmental, door contacts, motion detectors, etc.). Z-wave is utilized for home automation such as switches, lights, etc.
All sensors must be the appropriate compatible RF. In this case, 345MHz
Sensors like the Resolution Products RE219 or the 2GIG FT6-345 water leak detectors would be compatible.
