I am looking to get some thermostats for my 2Gig and looking for a good thermostat that works with the 2Gig Z wave side.
Anybody tried these out?
thanks.
Chris.
thanks.
Chris.
I would be apprehensive to suggest trying those for a few reasons:
Those two are not on any official compatibility lists for Alarm.com. You will want to generally stick strictly to that list for thermostats and door locks.
They are advertised specifically for use with Nexia. There have been more than a few problems with other such devices in the past.
The review I saw listed “Not being able to remotely set schedules” in the Con list. If true, I doubt any sort of support from Alarm.com would ever be added for these.
I have tested and installed over 30 of the Trane/American Standard 624 Thermostats without any issues.
The 824 does not work.
Some notes:
Be sure if using the Alarm.com scheduling feature to program thermostat you should turn off the “use Local Schedule” in the thermostat so they aren’t in conflict with each other.
Other than that this is as of today the most feature rich thermostat you can get that works with Alarm.com. Now depending on what you need or want to do many others will also work but their are some unique features that you can only get with this stat and no others.
Yes some of these items can be done with other stats except the BK wire option. But none can do all of these at the same time.
Here is why:
No other them
