alarm monitoring trigger from st hub
Hi, what triggers are available for suretydiy central monitoring? I have a smartthings hub that is connected to smoke detectors, door sensors and motion sensors. I have the ability to send emails, trigger relays or send specially formed IP packets (via custom ST apps). I do not want a separate alarm panel. Are there any options for me?
suretyDIY is an Alarm.com service provider and all Alarm.com compatible panels can work with our service. There are a wide variety of system options, however these are all professional security systems.
Smartthings automation hubs are not compatible. While you can use one as a secondary Z-wave controller along with most compatible Alarm.com systems, you cannot use the Smartthings hub to send any info to ADC.
Compatible panels can be found listed on our home page.
