Are the temp sensors supposed to perform the same on GC3 as they did on GC2? Mine appear to be working, however, I’m having to run a network rediscovery every day.
As I understand currently, the RTS is not yet fully compatible with the GC3. In fact, I believe it is only compatible at this time with the GC2 (and specifically, the newer hardware version of the GC2, an older panel model that has had firmware upgraded will have issues due to older Zwave version)
The RTS actually does not itself participate in network rediscovery.
It is and must be learned in through NWI (Network Wide Inclusion)
This means the RTS and panel must be in their respective final locations and then learned in. Typically you will want to learn all other devices into the panel first.
