Just finished installing our 2GIG system and am loving the new alarm set up. One problem I am seeing though is that Alarm.com is reporting our 5816 Patio Door sensor as Open when the 2GIG panel does not report it as such. Any ideas what the problem might be?
I’ve never seen a situation where a sensor shows the correct status on 2GIG but not on Alarm.com that is limited to just one sensor, with the other sensors working. Can you log into Alarm.com and look at the History tab? Open and close your doors and verify that you can see them opening and closing in the Alarm.com event history. You’ll have to refresh the History page to see the updates. Are you able to see the other doors opening and closing but not the patio door?
Yes that is correct, the patio door shows open pretty much all the time. I am considering to reset my panel to see if that may fix it. The cell signal says 9/10/11 depending on the time of day. Cell test comes back clean.
