Alarm.com Outdoor Wireless ADC-V721W
Outdoor Wireless (ADC-V721W)
The ADC-V721W is a wireless outdoor IP night vision camera. It provides HD 720P live and recorded video. This camera has been designed to see at a distance of over 40 feet in the dark (black and white) while still delivering true daytime colors thanks to the mechanical IR cut filter. Plus, wireless set-up is a breeze with push button wireless set-up using either wireless access point mode or the WPS button.
Included Accessories
  • Power Adapter (8 feet)
  • Input/output connecters
  • Wall screws
Specifications
Live resolution options 1280x960, 800x600, 640x480, 320x240, 176x144
Recording resolution options 1280x800, 600x400, 300x200
Live quality High, medium, and low compression options
Recording quality High and medium compression options
Recording compression H.264, MPEG-4
Image sensor 1/4” CMOS, 1280x800
Iris Fixed Iris, F1.8
Focal Length F=3.6mm
Field of view 62º (horizontal), 38º (vertical)
Low-light sensitivity 0 lux with IR on
IR LED illumination 40 Feet (12 meters)
Weatherproofing IP-66, with UV protection
Image adjustments Brightness, Contrast, Saturation, Sharpness, Exposure
Video motion detection 3 windows, adjustable sensitivity and threshold
Digital input trigger Yes
I/O Triggered Video Recording
Password authentication "Digest” authentication
Wi-Fi 802.11 b/g/n 2.4 GHz wireless protocols (WPA2 / WPA / WEP / None)
Simultaneous viewers 10
Privacy Button No
Operation temperature 32° ~ 104° F (0°C ~ +40°C)
Operating humidity 20% ~ 80% RH
Max power consumption 12V DC, 5W
Dimensions (LxWxH) 2.76", 1.65", 3.83"
Weight 4.2 oz.
Network requirements Minimum bandwidth 0.25 Mbps
