The ADC-VC836 from Alarm.com is a high performance fixed turret camera optimized for indoor and outdoor video monitoring. Its unique, compact design and outstanding HD quality video make the camera ideal for both commercial and residential video installations. The camera features a vandal-resistant exterior casing with an IP67 rating and Power over Ethernet (PoE) capabilities.
Camera Features
- Power over Ethernet
- IR night vision
- 1080p HD video
- IP67 rated waterproof & dust-tight
- Video Analytics, Video Motion Detection, and sensor-triggered clips saved to the cloud
Included Accessories
- Camera
- Camera mount
- Mounting hardware
- Drill template
- Water resistant cap
Specifications
| Live resolution options | 1920x1080, 1280x720, 640x360 |
| Recording resolution | 1920x1080, 1280x720 |
| Recording compression | H.264 |
| Image sensor | 1/2.8" Progressive Scan CMOS |
| Lens | 2.8 mm, F1.6 |
| Angle of view | 108° |
| Angle adjustment | Pan: 0 - 360°; Tilt: 0 - 75°; Rotation: 0 - 360° |
| Low-light sensitivity | 0 lux with IR |
| IR range | Up to ~95 feet (30 meters) |
| Image adjustments | Flip, brightness, contrast, saturation, sharpness, exposure |
| Ethernet connection | 10/100Mbps RJ-45 |
| Operating temperature | -22°F – 140°F (-30°C – 60°C) |
| Operating humidity | < 95% (non-condensing) RH |
| Power | 12 V DC ± 25%, 6W or PoE (802.3af, 36-57V, class 3), 7W |
| Dimensions (DxL) | 5 x 3.8” (12.7 x 9.6 cm) |
| Weight | 1.4 lbs. (620 g) |
| Ingress protection | IP67 |
| Compliance | UL Listed |
Network requirements
| Minimum bandwidth | 1.5 Mbps |
| PoE standard | IEEE 802.3af |
