Overview
The ADC-VC826 from Alarm.com is a high-performance fixed dome camera optimized for indoor and outdoor video monitoring. Its discreet, compact design and outstanding HD quality video make the camera ideal for both commercial and residential video installations. The camera features a vandal-resistant exterior casing with an IP67 rating and Power over Ethernet (PoE) capabilities.
Features
- Power over Ethernet
- IR night vision
- Vandal resistant
- 1080p HD video
- IP-67 rated waterproof & dust-tight
- This allows the camera to be mounted outdoors
- IP-67 also protects against the effects of immersion in water to depth between 15 cm and 1 meter when immersed for 30 minutes
- Video Analytics, Video Motion Detection, and sensor-triggered clips saved to the cloud
Included accessories
- Camera
- Camera stand
- Three mounting screws
- Three drywall anchors
- Drill template
- Torx wrench
- Water resistant cap
- Lens cleaning cloth
- Setup guide
Specifications
| Live resolution options | 1920x1080, 1280x720, 640x360 |
| Recording resolution | 1920x1080, 1280x720 |
| Recording compression | H.264 |
| Image sensor | 1/2.8" Progressive Scan CMOS |
| Lens | 2.8 mm, F1.6 |
| Angle of view | 108° |
| Angle Adjustment | Pan: 0 - 355°; Tilt: 0 - 75°; Rotation: 0 - 355° |
| Low-light sensitivity | 0 lux with IR |
| IR range | Up to ~95 feet (30 meters) |
| Image adjustments | Flip, brightness, contrast, saturation, sharpness, exposure |
| Video motion detection | 3 windows, adjustable sensitivity and threshold |
| Ethernet connection | 10/100Mbps RJ-45 |
| Operating temperature | -22°F – 140°F (-30°C – 60°C) |
| Operating humidity | < 95% (non-condensing) RH |
| Max power consumption | 12 V DC ± 10%, 5W or PoE (802.3af), 6.5W |
| Dimensions (DxL) | 4.4” x 3.2” (11.1 x 8.2 cm) |
| Weight | 500 g (1.1 lbs.) |
| Ingress protection | IP67 |
| Impact protection | IK10 |
| Compliance | UL Listed |
Network requirements
| Minimum bandwidth | 1.5 Mbps |
| PoE standard | IEEE 802.3af |
