The ADC-VC825 from Alarm.com is a high-performance fixed dome camera optimized for indoor and outdoor video monitoring. Its discreet, compact design and outstanding HD quality video make the camera ideal for both commercial and residential video installations. The camera features a vandal-resistant exterior casing with an IP66 rating and Power over Ethernet (PoE) capabilities.
Features
- Power over Ethernet
- IR night vision
- Vandal resistant
- HD video
- IP66‑rated waterproof & dust-tight
- This allows the camera to be mounted outdoors
Included accessories
- Camera
- Camera stand
- Three mounting screws
- Three drywall anchors
- Drill template
- Torx wrench
- Water resistant cap
- Lens cleaning cloth
Specifications
| Live resolution options | 1280x720, 640x360, 320x180, and 176x100 |
| Recording resolution | 1280x720 |
| Recording compression | H.264 |
| Image sensor | 1/2.8" Progressive Scan CMOS |
| Lens | 2.8 mm, F2.0 |
| Angle of view | 106° |
| Angle Adjustment | Pan: 0 - 355°; Tilt: 0 - 75°; Rotation: 0 - 355° |
| Low-light sensitivity | 0 lux with IR |
| IR range | Up to 30 meters (~95 feet) |
| Image adjustments | Brightness, contrast, saturation, sharpness |
| Video motion detection | 3 windows, adjustable sensitivity and threshold |
| Ethernet connection | 10/100Mbps RJ-45 |
| Password authentication | “Digest” authentication |
| Simultaneous viewers | 6 |
| Operating temperature | -30°C – 60°C (-22°F – 140°F) |
| Operating humidity | < 95% (non-condensing) |
| Max power consumption | 12 V DC ± 10%, 5 W PoE (802.3af) |
| Dimensions (WxH) | Φ111 × 82 mm (4.4 × 3.2”) |
| Weight | 500 g (1.1 lbs.) |
| Ingress protection | IP66 |
| Power supply | PoE; also compatible with the US Adapter (ADC-VACC-PWR-VC101) Note: This device is hardwired-only. |
Network requirements
| Minimum bandwidth | 0.25 Mbps |
| PoE standard | IEEE 802.3af |
