Alarm.com Indoor/Outdoor Bullet Camera ADC-VC736
The Indoor/Outdoor Bullet Camera (ADC-VC736) from Alarm.com is a high-performance indoor/outdoor bullet camera with powerful night vision capabilities. With its 1080p HD quality video and highly visible design, the ADC-VC736 provides a strong visual deterrent that is ideal for both commercial and high-end residential video installations. The camera features commercial-grade construction with an IP-67 rating and Power over Ethernet (PoE) capabilities.
Camera features
  • Power over Ethernet
  • Powerful IR night vision
  • 1080p HD video
  • IP67-rated waterproof & dust tight
  • Video Analytics, Video Motion Detection, and sensor-triggered clips saved to the cloud
Included accessories
  • Camera
  • Camera stand
  • Mounting hardware
  • Drill template
  • Water-resistant cap
Specifications
Live resolution options 1920x1080, 1280x720, 640x360
Recording resolution 1920x1080, 1280x720
Recording compression H.264
Image sensor 1/2.8" Progressive Scan CMOS
Lens 4 mm, F1.6
Angle of view 86°
Angle Adjustment Pan: 0 - 355°; Tilt: 0 - 75°;
Rotation: 0 - 360°
Low-light sensitivity 0 lux with IR
IR range Up to ~260 feet (80 meters)
Image adjustments Flip, brightness, contrast, saturation, sharpness, exposure
Ethernet connection 10/100Mbps RJ-45
Operating temperature -22°F – 140°F (-30°C - 60°C)
Operating humidity < 95% (non-condensing) RH
Power 12V DC ± 25%, 10W or PoE (802.3af, 36 – 57V, class 3) 12.5W
Dimensions 4.1 × 11.8″ (10.5 × 30.0 cm)
Weight 2.65 lbs. (1200 g)
Ingress protection IP67
Compliance UL Listed
Network requirements
Minimum bandwidth 1.5 Mbps
PoE standard IEEE 802.3af
Setup and Installation
Troubleshooting
