The Geo-Service device in malfunction trouble condition indicates the Alarm.com servers have not received a location report from the Geo-Device (usually a cellphone) for a 24 hour period.
Another common cause for a Geo-Service device malfunctioning is because the device may have been deleted but not completely removed from the account. The best way to clear a Geo-Service device malfunction is to completely remove the device from the account before attempting to reattach the device to the account.
It is recommended to remove Geo-Devices that are not active or currently in use on the account in order to avoid Geo-Service device malfunctions
How to resolve:
To clear the Geo-Service device in malfunction trouble condition:
Note: Clearing the Geo-Service device in malfunction trouble condition only clears the trouble condition once each time the following steps are taken.
Complete the following steps for all Geo-Devices that are in malfunction or no longer in use on the account:
- Log into the Alarm.com mobile app on the device in malfunction.
- Tap Menu.
- Tap App Settings.
- Tap Location Services.
- Tap the Location Services toggle switch to turn it off.
- Log out of the Customer app.
- Log into the Alarm.com Website.
- Click Settings.
- Click Places.
- If the malfunctioning or not in use device is listed in Manage Devices:
- Click to select the desired device.
- Click Trash Can Delete Icon to remove the Geo-Device from the account.
- Click Ok.
- While staying logged into the Alarm.com Website, log into the mobile app on the desired Geo-Service device.
- Tap Menu.
- Tap App Settings.
- Tap the Location Services toggle switch to turn it on.
- On the Alarm.com Website, click to refresh the Places page or log back in if necessary.
- Verify the device is showing in the Places devices section.
To disable the malfunction report using the Customer Website:
If you do not want a malfunction report, you can turn off the report using the Alarm.com Website.
Note: This only applies to Android devices.
- Click Settings.
- Click Places.
- In Manage Devices, click the name of the Geo-Device to be edited.
- Click to uncheck Report Malfunction if Device fails to check in for 24 hours.
- Click Save.
