Alarm.com CSVR can not log in
I have an alarm.com CSVR already hooked up to several cameras. I finally got it installed on my surety account. Now when I try to log into the CSVR directly, both my surety and alarm.com password do not work. MAC [removed by admin]
With the CSVR, it uses a password that is different than your Alarm.com or Surety login.
If you need to change the password on the CSVR:
  1. Log in to the Alarm.com Customer website
  2. Click Video
  3. Click Settings
  4. Select your CSVR
  5. Click Local Display
  6. In Local Device Password , enter the desired password
  7. Make sure Password Protection is checked if you want the password requirement to stay enabled.
  8. Click Save
Are you able to update the password and log in locally using those steps?
