Is alarm.com app and devices in zwave network compatible with Alexa…any known major issues?
Thanks!
Yes, you can integrate Amazon Alexa and your Alarm.com account. The quick start guide can be found here. In addition, since release Alarm.com has been added as a Home Skill. See this post for more detail.
Example Commands: (now you can nix the “Ask Alarm.com” part from lights/thermostats if you set it up as a home skill)
Security
Alexa, ask Alarm.com to arm my system. (System will arm to Arm Stay.)
Alexa, ask Alarm.com if my security system is armed.
Alexa, ask Alarm.com to Arm Stay my system.
Locks
Alexa, ask Alarm.com to lock the Front Door.
Alexa, ask Alarm.com if the Basement Door is locked.
Garage
Alexa, ask Alarm.com to close the Garage Door.
Alexa, ask Alarm.com if the Garage Door is open.
Thermostat
Alexa, ask Alarm.com to make it warmer. (Increases the target temp by 2 degrees F or 1 degree C.)
Alexa ,ask Alarm.com what the thermostat temperature is.
Alexa, ask Alarm.com to set the heat to 72.
Video
Alexa, ask Alarm.com to record a clip on the Living Room camera.
Alexa, ask Alarm.com to point the Living Room camera at the dog crate preset.
Lights
Alexa, ask Alarm.com to turn on the Bedroom Light.
Alexa, ask Alarm.com to turn off the Living Room Light.
Note that you will need to replace device names with the names of devices you currently have on your system.
