Aeotec Energy Monitor
Question about the Aeotec energy monitor:
Does this only show you the power for the circuit it is monitoring (like the main lines coming into your panel) or can it also show you which appliance is drawing various power loads (based on harmonics)?
Or, to see individual load numbers for circuits/appliances, would I need to purchase multiple Aeotec devices - one for each 220 circuit?
Looking to monitor the main, plus several 220 appliances - 2 HVAC units, Pool Heater, etc. and having to purchase three or four of the Aeotec units sounds crazy expensive. Unless they make a unit closer to the Emporia that has multiple sensors? Thanks.
An Aeotec Home Energy Meter monitors the energy usage of all devices tracking overall energy usage across multiple devices and power phases in a household.
It looks like you need the Aeotec Heavy Duty Switch controls a single high-power device and can monitor its energy consumption. It is designed for specific high-power applications (pool equipment, EV Charger, …), handling high amperage and voltage. These are however one for each device you want power monitoring on.
