I am looking to install a new, mostly-wired security system at a residence that I will be impossibly far from for months at a time. I will have to call on favors from friends to go up to the property, and so wish to limit the potential for false alarms as much as possible.
The suretyDIY address check reports Full Coverage for Verizon and T-Mobile, and I am only looking at solutions that report over (LTE) cellular. I will have internet, but don’t want to rely on it.
I am considering a basic burglar/fire alarm system that could work all by itself (like my cellular Honeywell system does at home), to which I plan to add suretyDIY’s alarm.com service. If, for any reason, alarm.com doesn’t work out, I’d need to be able to fall back on a basic, conventional cellular radio that works with whatever panel I have.
I will be running wires myself for smokes, motion detectors, etc. I will also need to rely on at least one wireless smoke and one wireless motion detector for a nearby, detached garage that I can’t run underground wires to. I hope to hire an independent installer to come and review my work, and possibly help with any issues getting set up with suretyDIY’s alarm.com service.
I’m not happy about buying cameras that can only work with alarm.com. I’ve worked as a network engineer and run a separate virtual lan at home for my own IP camera installation. I also like being in total control of access to cameras in my house, so I’ll probably do a separate camera installation at this location also. I’m just pushing images to a location in the cloud, so I can easily keep the firewall locked down for this. Also, if I understand correctly, alarm.com video requires an internet connection, so I’m not gaining internet independence with alarm.com video.
Being able to remotely turn the water on/off is something I’d like to be able to do, and that may be an advantage to alarm.com over a conventional cellular radio system. If I was to implement this myself using the internet, I’d probably have to run a server onsite, worry about it restarting correctly after power failures, and open my firewall to incoming connections (which gets complicated and non-trivial to protect).
Remote monitoring of the (preferably huge) backup battery would be very nice.
I have heard that Honeywell can be difficult to deal with if you need something like a firmware update and you are not a dealer. The Interlogix Concord seemed like it might be a straight-forward choice. It seems like some functionality is getting migrated from various panels to the key/touchpads in some configurations? Including alarm.com adds yet another layer to my confusion. A fancy, capacitive touch keypad is certainly nice, but I wouldn’t want to add complexity or dependancies, and expect that I could be quite happy with a basic panel and a simple keypad, if it is all extensible enough.
I am hoping that you can suggest systems that are well-known and well-supported by installers, for which the basic system supports both wired and wireless (non-proprietary) sensors, can function with cellular communication on its own, and which is well-suited to being supported by alarm.com.
Thank you!
Bill
