Is the ADT Command 7” touchscreen **AIO ADT7AIO compatible with Surety.com? Also, are the sensors compatible? If not, what control panel replacement is recommended?
The ADT Command panel is an ADT proprietary panel and cannot be used with Surety. You can use an IQ Panel 5 but the legacy card needed depends on the sensors you have as not all sensors use the same frequency. Can you send a picture of a wireless sensor and/or motion?
