What is the best adhesive to attach a window contact to a vinyl window frame
Adhesive
Hi Jim,
I would suggest using the Scotch Extreme outdoor double sided tape. It’s what we use when doing installations. Here’s a link.
Cleaning the surface before applying the tape is key. Wipe the surface with alcohol first, let it dry completely and then apply the permanent double sided tape.
