How can i add my Wink hub
Happy to assist!
Pairing the Wink hub with the Concord 4 is not a supported feature. However, the Concord 4 Alarm.com module instructions do mention steps for installing a Z-Wave controller. From the manual:
If installing a portable Z-Wave controller, first add the controller to the Alarm.com Z-Wave network using the Concord panel, and then use the portable controller to add the remaining devices to the network while the devices are in their permanent locations. (Locks cannot be added to the controller, and will need to be added by the Alarm.com module.) Devices must be within 6 ft. of the controller if a controller is being used to learn in devices.
How to Add a Z-Wave device to the Alarm.com module’s network:
Put the Alarm.com module into Z-Wave Add mode. On the Alarm.com module, press and hold down the ZWave Mode button for a few seconds, until the LED L2 begins flashing a 4-blink pattern to indicate Z-Wave Add
mode.
Steps for the Wink’s inclusion mode can be found at the bottom of this page.
